Suche mal im Mapping Bereich den Punkte SAMP1 - SAMP4
dort jeweils zuweisen:
samp1:
action_deck 1 ? sampler 1 select & var '$samp' ? sampler 1 play_stutter : var '$shift' ? sampler 1 play_stutter : sampler 1 play_stop : action_deck 3 ? sampler 1 select & var '$samp' ? sampler 1 play_stutter : var '$shift' ? sampler 1 play_stutter : sampler 1 play_stop : sampler select 5 & var '$samp' ? sampler 5 play_stutter : var '$shift' ? sampler 5 play_stutter : sampler 5 play_stop
samp2:
action_deck 1 ? sampler 2 select & var '$samp' ? sampler 2 play_stutter : var '$shift' ? sampler 2 play_stutter : sampler 2 play_stop : action_deck 3 ? sampler 2 select & var '$samp' ? sampler 2 play_stutter : var '$shift' ? sampler 2 play_stutter : sampler 2 play_stop : sampler select 6 & var '$samp' ? sampler 6 play_stutter : var '$shift' ? sampler 6 play_stutter : sampler 6 play_stop
samp3:
action_deck 1 ? sampler 3 select & var '$samp' ? sampler 3 play_stutter : var '$shift' ? sampler 3 play_stutter : sampler 3 play_stop : action_deck 3 ? sampler 3 select & var '$samp' ? sampler 3 play_stutter : var '$shift' ? sampler 3 play_stutter : sampler 3 play_stop : sampler select 7 & var '$samp' ? sampler 7 play_stutter : var '$shift' ? sampler 7 play_stutter : sampler 7 play_stop
samp 4:
action_deck 1 ? sampler 4 select & var '$samp' ? sampler 4 play_stutter : var '$shift' ? sampler 4 play_stutter : sampler 4 play_stop : action_deck 3 ? sampler 4 select & var '$samp' ? sampler 4 play_stutter : var '$shift' ? sampler 4 play_stutter : sampler 4 play_stop : sampler select 8 & var '$samp' ? sampler 8 play_stutter : var '$shift' ? sampler 8 play_stutter : sampler 8 play_stop
hab es so bei mir drin stehen und ich kann damit nun mit deck 1 die Sampler 1-4 Spielen und auf deck 2 die Sampler 5-8
hoffe es geht auch bei dir.
Sichere vorher dein Mapping.
samp1:
samp2:
samp3:
samp 4:
geposted Wed 31 Jul 13 @ 4:31 pm
@nuky
Bingo. Das isses. Danke
geposted Thu 01 Aug 13 @ 3:45 pm
gleich das nächste:
Sample Lautstärke!
Beispiel:
Fader der Denon 2 oder 3 (Deck 1 oder 2) auf Vollanschlag.
Will ich nun einen Sample einspielen, muss ich den Sample fader behandeln wie ein rohes Ei.
Bereits nach ca. 10% übertönt die Lautstärke des Sample den gespielten Titel.
Über den Kopfhörer ist alles gut und von der Lautstärke nicht lauter als der gespielte Titel
Oder könnte ich die 12 Samples mit nen Korg Kontol steuern?
Sample Lautstärke!
Beispiel:
geposted Thu 01 Aug 13 @ 4:11 pm
Natürlich kannst du das.
Allerdings weiß ich nicht, ob das dein Lautstärke Problem löst.
Der Korg ist ja nur ein anderer Controller mit dem die Sampels dann abgefeuert werden.
geposted Fri 02 Aug 13 @ 3:22 am
