OK On the Colored wave bar the movement is great until I move mouse over the turn table areas then it freezes up. Doesn't seem to effect the music at all but it stops the wave visual and is hard to tell beat.
Any help with this would be great!?!? I am confused.
geposted Sun 11 Aug 13 @ 12:23 pm
Sounds like a graphics card issue. Have you checked fo any graphics card updates?
geposted Sun 11 Aug 13 @ 12:45 pm
Windows 8 ? check this .. https://virtualdj.com/forums/175243/PC_Version_Technical_Support/Windows_8_Lag___7_3.html (11th post)
If not, then dont use the skin in maximized mode. Use a skin that has the same resolution as your screen
geposted Sun 11 Aug 13 @ 12:50 pm
mine freezes when I move the mouse within the browser area..
geposted Sun 11 Aug 13 @ 12:59 pm
