So i went into the users/doc/blah blah blah and found the current and blank database file VDJ 7 keeps making. Replaced it with the datbase file i want it to use and restarted VDJ 7
It wont use the database file i keep sticking in there. All its doing is negating it and continues to make its own new one
Any help much apprecaited.
This is strictly to use my old history lists which i use very frequently
All i have ever done before on any other upgrade is remove and replace this database XML file with my saved and backs up one and it always worked
Any help much appreciated
geposted Sun 11 Aug 13 @ 8:20 pm
So you try to move from one to another computer?
Please have a look here:
https://virtualdj.com/wiki/How%20do%20I%20transfer%20the%20software%20from%20my%20old%20computer%20to%20my%20new%20computer.html
If not and you just want to go on the same computer from V6 to V7, you just need to install the V7 and then start it!
geposted Mon 12 Aug 13 @ 2:37 am
