Forum: VirtualDJ Plugins
Topic: ShowLogo+ - Page: 1
New showlogo effect:
* Drag and drog positioning in the plugin window
* Precise mask colour selection
* Basic animations
* Transparancy
This is v1.0 so may be a few niggles, particularly the flickering in the plugin window which I will resolve soon!
http://www.virtualdj.com/addons/16151/showlogo_.html
geposted Tue 13 Aug 13 @ 6:40 pm
Your forcing me to return back to a PC Scott, lol!
I'm sure it's a great plugin and your work is always appreciated.
Works great! Thanks Scott.
Beatbreaker Could you tell me why you switch to Mac, and the real benifits ?. Thanks
Any suggestions of somewhere to find an easy logo animator?
This plugin doesn't support animated logos. It does basic animation itself.
Ahhh, maybe I should take a closer look then... =)
Awesome plugin.
Hey,
Cant get it to work.
The old Showlogo complians that file "d3dx9_32.dll" is missing.
Could it be the same fault that it doesent works?
Maybe it´s only for windows 32-bit. I have a 64-bit windors version.
Or other sugestions?
It´s getting closer but not working,
Now when I installed it can load files in showlogo and showlogo+ but everytime I push "activate" nothing happens.
I got the same problem on my new laptop. On my old computers there´s no problem.
Same thing with slideshow,
anybody knows the solution?
you must hardware acceleration ON
Just saw a animation that perhaps you could add to this, as it's a combination of two your plugin animations.
It is a couple vertical rolls followed by a couple horizontal rolls, then repeat.
Simple but looks good.
win8.1
VDJ 7.4.1
not works / switch on = blank
win8
vDJ 7.4 =Ready
No, works like a charm.
Testing it at the moment.
Wada?...I forgot to install this!...was still using the first version.checked it out last nite....Scott...I have to say this is awsome bro!...looks great with milkdrops behind it!...that's my boy...yeah!
well here we are again...I'm reporting this problem and threads get locked!...please...took me plenty to start a new channel on youtube for more personal videos and bug fixing...now check at @ 1:52 in the video.I open the Showlogo+ and its off by a mile.it gets fixed when I realise the resolution issue..
Yeah, I think thats the same bug I reported earlier.
PachN wrote :
Currently, if I have selected a plugin (for scrolltext v2 and showlogo+ I can tell for sure) the activation button and param slider all show up. That's ok.
Now, I have mapped a button with the action "browser_zoom". If I run this action, the browser will maximize and still everything is ok.
After pushing "browser_zoom" again, browser resizes to its default dimension, but now I can't see the plugin buttons and sliders anymore.
Seem like they slip down out of the visible browser part.
You have to select another plugin and back to the one you acutally would like to have, to bring the controls up again.
when I select the showlogo+ plugin everything is blank, no sliders, no menu options, nada
win 8 dell 660 inspiron 8gb ram intel hd video card
might be a windows 8 issue Graphix?...
33%
