Forum: Old versions
Topic: Virtual dj LE version
Hi,
I've got a question about virtual DJ LE
The current version isn't 7.4 ?
Because i'm in 7.0.5 and when I check for update it's say's no updates available.
Os : OSX
Thanks
geposted Wed 14 Aug 13 @ 3:25 pm
Most LE versions are not eligible for updates. To keep up to date with the latest version you need Pro.
Keith
Ok thanks for reply
Hey I have a ddj wego le software installed in my Mac !!!! I have misplaced the cd and want to install it on my laptop also!!!!please be kind to help
And I have a serial number printed on the box I can't register it with virtual dj!!!please help
Julien6931 wrote :
Hi,
Os : OSX
Thanks
Beatmix LE version is at version 7.4 currently. Check your Download Center.. https://virtualdj.com/download/updates.html
I've lost my serial number where can i get a new one?
Please open a ticket, send us your controller reciept and we will have a look what we can do for you! :-)
Virtual DJ LE keeps crashing on startup. I just purchased the Gemini G2V and I am running
Snow Leopard 10.6.8 (recommended)
Intel DuoCore Processor (recommended)
1280 x 800 Resolution (requirements)
Soundcard- I don't see CoreAudio, I see Intel High Definition Audio
4gb Ram (recommended)
100 gb on hard drive (recommended)
I followed the instructions and opened VDJ LE after the VU meters went off and i received the error message that starts with this:
Dyld Error Message:
Symbol not found: _QTValidateAudioChannelLayout
Referenced from: /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
Expected in: /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
I've tried it multiple times, but the same thing keeps happening. Any idea on what I should do?
I just bought a gemini g2v off CL and the guy won't give me the serial number for the virtual Dj software is there another way to get it I'm not a pro Dj just got it for my basement.
Serial numbers are not transferrable. He's right not to give it to you.
You'll need to buy yourself either a Plus (controller) license or a monthly subscription license.
