Hi Guys
I'm currently using my new Denon MC6000 with virtual dj.
I have a problem listening to the cued song through the headphones, it only lets me listen to the song playing.
Is it a set-up problem? Hope it's nothing big as I have a massive gig on the weekend.
Thanks in advance.
Cheers
Thanks in advance.
Cheers
geposted Tue 20 Aug 13 @ 6:33 am
Make sure the Switch on the back is set correctly for the Mode you are using eg. PC mix or external
Keith
Keith
geposted Tue 20 Aug 13 @ 6:35 am
geposted Tue 20 Aug 13 @ 7:07 am
I'd say check the mixer's settings on the back of the board. I've had that problem. You need to set it up exactly as stated in the MC6000 page on here.
geposted Fri 30 Aug 13 @ 4:41 pm
Disable the crossfader in config.
geposted Sun 01 Sep 13 @ 10:49 am
I just picked up three 6000's at GC and am having the same issue with the cues. I can get them to work but have to jump through hoops to do so. Every time I restart the program, I have to do this crazy mix of button switching and back again to get the cues to work.
geposted Thu 19 Sep 13 @ 3:03 am
