Hi, I have a Mac computer and a DDJ-WeGo controller and I downloaded the Virtual DJ LE and my Controller only works for approximately 10 Mins and says that I will have to upgrade to Virtual DJ Pro for my controller to work.
So just wondering if there is any way around it as I really don't need the Pro version, all I want is the Controller to work.
See Picture Below
Cheers
[IMAGE1]
Once you use VirtualDJ LE that comes with the controller or VirtualDJ Pro Full (as you have it registered now) you wont have any issues. This 10 minute frame is only if you use a different VirtualDJ option (Home, Broadcaster, Basic) and not the bundle VirtualDJ LE or the upgrade (and register) to VirtualDJ PRo Full. ACW VirtualDJ Support.
See Picture Below
Cheers
[IMAGE1]
geposted Tue 20 Aug 13 @ 7:13 pm
Hi i have exactly the same problem.
Can anyone help please?
geposted Wed 21 Aug 13 @ 6:08 am
Please contact support: https://virtualdj.com/contact/
geposted Wed 21 Aug 13 @ 8:52 am
