Hi,
I use a Reloop Beatmix with the included VDJ LE.
For the past couple months I've been able to record mixes etc. without a problem. However, just recently have I been experiencing problems with the gain levels when recording.
The problem arises when I attempt to play my recorded mix/whatever, where the gain levels will be way below 0. Like -40 or some crap like that. It's really frustrating because I can't seem to figure out what the heck is wrong. Everything else is the same as before, other than this annoying problem. Even more frustrating is when I spend hours getting everything right, only to find out that the audio is barely audible.
Hope someone will give me a good explanation/solution for this, thanks!
geposted Fri 23 Aug 13 @ 7:07 pm
