I have recently downloaded the latest ddj sx driver but from some reason it uses 2 channels on the mixer for each deck (that's if your using only two decks) for example it would use both channels 1&2 for the left deck instead of just one ?
This is annoying be because if I was using just channel 1 on the mixer and I knock the channel just a little bit it will change the software internal mixer Accordantly Four example on the first channel I can have the Lowest EQ On zero And on the second channel I could have the EQ set to halfway If I was to knock the first channel it would Automatically make the second aswell
Also this would mean as a external mixer it's using up two channels it doesn't need to that could be used for something else
Please help :)
Please help :)
geposted Thu 29 Aug 13 @ 3:58 am
Please do not post the same message or question more than once.
You have already asked this question in the following topic https://virtualdj.com/forums/180931/Hardware_Technical_Support/Ddj_sx_mixer_help_.html
geposted Thu 29 Aug 13 @ 5:29 am
