Hi,
I'm using Numark Mixtrack Pro II and Virtual DJ. When manually setting the pitch of a song via the slider on the Numark controller I have problems with the precision of it. I takes a lifetime to set it to, for example, 128 BPM. I always get 128.24 or 127.96 etc.
Is there a way, or plugin, that can round that number?
For example, if it currently is 128.24, I want to round it to 128.00 with a press on a button or any other way.
Thanks
Thanks
geposted Mon 02 Sep 13 @ 8:28 am
Please see https://virtualdj.com/wiki/MIDI%20controller%20pitch%20precision.html
Setting a smaller pitch range will help. You can also map buttons or keyboard shortcuts to pitch -0.01% / pitch +0.1% to make fine adjustments.
To be able to customise the mappings, you will need to upgrade to the full VirtualDJ Professional: https://virtualdj.com/buy/
geposted Mon 02 Sep 13 @ 10:31 am
