i recently bought the numark mixpro which i got told came with virtual dj le but it didnt. ive downloaded it off the numark website but it asks for a serial code which i understand comes on the sleeve of the software cd which i dont have.
is there anywhere i can get or buy this software or obtain a serial number?
i know theres alot about them on here ive spent all day searching through but i cant find an answer.
thanks
jimmyh
thanks
jimmyh
geposted Mon 02 Sep 13 @ 4:49 pm
Your best bet is contact support https://virtualdj.com/contact/ see if they can help you out.
If the unit was purchased used then the serial number has already been used. You will need to purchase VDJ Pro https://virtualdj.com/buy/ to use it with this software.
geposted Mon 02 Sep 13 @ 8:35 pm
Please contact support and submit a ticket: https://virtualdj.com/contact/
Thanks!
Thanks!
geposted Tue 03 Sep 13 @ 1:35 am
Where can we find the actual phone numbers to contact support?
geposted Fri 06 Sep 13 @ 11:08 am
Just ask anything in that space where it says ask. Then you see the different options of contact(including phone number).
geposted Fri 06 Sep 13 @ 11:35 am
i have my mixtrackpro but after install software version 7.0.4 serial no. is invalid,, i download vdj home free but limited to 10 minutes only can you please help me to get fulll version.. thank you. my email add [removed]
[Sorry, E-mail addresses and other contact details may not be posted in the forums by unlicensed users. Please read the forum rules]
geposted Tue 29 Oct 13 @ 4:38 am
Please contact support for assistance with serial number problems: https://virtualdj.com/contact/
geposted Tue 29 Oct 13 @ 6:10 am
Hola me podéis decir cual es serial de la controladora numark n4....ya que e perdió el software y necesito el serial!!!!muchas gracias
geposted Wed 20 Nov 13 @ 3:16 pm
If your ticket doesn't pan out, try:
Numark Products
http://www.numark.com/authorizationhelp
401-658-3131
Numark Products
401-658-3131
geposted Thu 21 Nov 13 @ 1:46 am
This is the english Forum...please post your questions in englisch or use the forum of your language
https://virtualdj.com/forums/12/Spanish_Forum.html
geposted Thu 21 Nov 13 @ 1:56 am
hello
I buy a pioneer DDJ-Wego and I install the serial number in that computer, y buy a new computer, how can I change the serial number?
thanks
thanks
geposted Sat 07 Dec 13 @ 7:54 pm
Simply uninstall the software from the old computer and then install it on the new one.
We would recommend registering the serial number to your profile so that you can easily retrieve it in future and download the software again from the download center. You can also use it to upgrade to the full VirtualDJ Pro at a discount.
Please see https://virtualdj.com/wiki/Can%20I%20install%20the%20software%20on%20a%20new%20computer%20or%20more%20than%20one%20computer.html
geposted Sun 08 Dec 13 @ 4:39 pm
