Hi all!!
Since a couple of days I experience an error in my sync button.
When I load a track on a deck and press the sync button, it wont syncronise the track with the other deck. Sometimes it does, sometimes it just wont.
Can anybody help me out with this one?
geposted Thu 05 Sep 13 @ 7:22 am
What is the difference in BPM between one track and the other? What % is your pitch control set to?
The sync button only works if the pitch % is high enough to match the tempo.
geposted Thu 05 Sep 13 @ 7:35 am
If you are using a 4 deck skin, make sure that the correct deck (The one playing out live) is set as the master deck.
Please see our FAQ pages: https://virtualdj.com/wiki/Masterdeck.html
geposted Thu 05 Sep 13 @ 7:40 am
If your using a four deck skin then this could be your issue https://virtualdj.com/wiki/Masterdeck.html
Otherwis as above comment, you will have to adjust the pitch range by clicking the pitch percantage ranges on your skin.
Edit: Didn't realize staff responded.
geposted Thu 05 Sep 13 @ 7:45 am
Thanks for your replys! I'll try this evening! I'll let you know if it worked out! Thanks!
geposted Fri 06 Sep 13 @ 3:34 am
Problem solved, thanks!
geposted Sun 08 Sep 13 @ 2:19 pm
