I have a macbook pro and virtual dj has just stopped working. I used it yesterday and it worked fine. Now when i try to turn it on. It says "virtual dj pro FULL quit unexpectedly" I tried doing a clean reinstall, reinstall, deleted all the folders and files, and nothing. It wont work. It wont open up. Does anyone know what the problem might be?
Please help!
Please help!
geposted Thu 05 Sep 13 @ 8:30 pm
I just recently got the same message, I'm using Cue...it quit at the start of the night a couple of times so I ended up using Traktor with no videos for the rest of the night...testing the system now at home, same symptoms...but just noticed if I don't use the text plug in, seems to keep working...but I need to let it go for a few hours and double check this theory...not sure...
geposted Fri 03 Jan 14 @ 4:56 pm
