Hey DJs,
I have on my mac Virtual DJ Version 6.1.2 LE, an older version which came with the Mixtrack Pro.
I recently acquired a Numark Mixdeck for a company I'm working for. I downloaded all the drivers and the software I have will not detect the controller. I am wondering if there is a way to get this to work? Am I out of luck? Need newer software?
Any help is much appreciated.
Cheers.
Cheers.
geposted Fri 06 Sep 13 @ 3:18 pm
The software that came with your Mixtrack is ONLY for your Mixtrack. You'll have to buy VDJ FULL PRO in order to use the Mixdeck.
geposted Fri 06 Sep 13 @ 6:01 pm
Assuming that it's not second hand and/or has already been used, you can upgrade from VirtualDJ LE to the full Pro at a discount by going to https://virtualdj.com/buy/ and entering your LE serial number in the box provided.
geposted Sat 07 Sep 13 @ 1:25 pm
