Hi Guys
I bought the DDJ Wego last week, managed to get it working on my netbook, everthing was working fine played around with it for about an hour, then I was messing aroung with the skins, just trying out different skins, and the wego stopped working!
every since then my computer won't recongnise the WEGO, I've read through all the threads, tried reinstalling the drivers tried different USB ports, even did a system recovery to the week before I bought the WEGO, and nothing seems to work.
The laptop is an acer aspire one AO722, although not very powerfull, it is able to run running VDJ LE (without a controller) it has the bare minimum of programs running, CPU Level in VDJ is usually between 25% and 75%.
all in all whenever I try to connect I get the "USB DEVICE NOT RECOGNIZED" message.
The only thing I havent done is update the WEGO firmware, could that be the issue?
any help here would be much appreciated, I really want to keep this controller!
geposted Wed 11 Sep 13 @ 1:16 pm
You might be having one of these issues https://virtualdj.com/wiki/midinotdetected.html
Try the firmware update then make sure you have the proper sound configuration https://virtualdj.com/wiki/DDJ-WeGO.html
geposted Wed 11 Sep 13 @ 9:49 pm
