Hi, I've just purchased VDJ pro. I've been using PCDJ VJ for 5 years now, so I thought it was time for an upgrade. I've been using a DAC3 controller with the boggis mapper installed when running the PCDJ VJ and I'm quite used to it. When I use the DAC3 with VDJ will the buttons do the same functions? If not, then is there a manual available which tells me what the buttons do when using it with VDJ. Any help appreciated.
geposted Fri 13 Sep 13 @ 6:31 am
In the native mapping, buttons on a controller where possible will perform the function that's written on them.
There is no manual, but you can easily see what each button does by going to CONFIG -> Mappers and choosing the DAC-3 in the drop-down list.
You can also optionally change the mappings to suit your own preferences: https://virtualdj.com/wiki/How%20do%20I%20change%20the%20mapping%20for%20a%20button.html
NOTE: Mappings for native controllers are intentionally kept simple, but it's possible to create more complex mappings using VDJscript.
geposted Fri 13 Sep 13 @ 6:46 am
