Hey I Just Brought The Numark MixDeck Off Of A Friend And I Have Virtual Dj 7.4 LE
Im Having Problems With Virtual Dj Clipping (Freezing) When I Press Play. I Also Have The Numark IDJ3 And It Works Fine With Out Clipping... Please Help I Can Only Mix With Cds..
I Also Having A Probelm With The Mapping The CrossFade Does Not Work But The Tempo And Track Finer Works
Thank You For Your Help
geposted Sun 15 Sep 13 @ 7:32 pm
Please don't double post. Also read the forum rules as posting private emails is not allowed https://virtualdj.com/wiki/Forum%20Rules.html
The only versions that work with the Mixdeck is the LE version that came supplied with that controller or VDJ Pro. Since you bought it second hand, the serial number might have already been used. If that is the case you could use the upgrade from the idj3 to purchase VDJ Pro at a discount https://virtualdj.com/products/oem.html
The mixer section on that controller is anolog so you wont be able to see it move in the software. But here's the correct configuration https://virtualdj.com/wiki/MixDeck.html
geposted Sun 15 Sep 13 @ 8:16 pm
Thank You Man & Sorry For That Im New Too Virtual Dj I Was Just Trying Too Solve The Problem Fast.
I'll Let You know If It works Thank You Again
geposted Sun 15 Sep 13 @ 8:29 pm
Hi, I have a Virtual DJ Pro Full for my Mixdeck, MY PROBLEM IS THE SOUND,ITS MAKE CHAPPING SOUND AND AND ITS DOESNT GO
PROPERLY BETWEEN THE MIXDECK AND THE SOFTWARE. PLEASE HELP.....BONO.SWITZERLAND
geposted Fri 18 Oct 13 @ 4:37 pm
First, please do not post in ALL CAPS. This is bad etiquette and considered shouting by most Internet users. Please read the forum rules.
Make sure that your computer has been optimised for DJ performance: https://virtualdj.com/wiki/Performance%20Issues.html
Once you have done this, check that the MixDeck is also configured correctly: https://virtualdj.com/wiki/MixDeck.html
geposted Sat 19 Oct 13 @ 10:49 am
