for the last two weeks, when I mix videos suddenly occurs that, when I lunch a new video to the available deck, this last one doesn´t load and return error. Then, if I click the song again, by the second time trying it loads, but the video does not appear... therefore, I go to set up and deactivate and activate the video, and it appears again... but the problem doesn't end with this... the same error occurs over and over again with all the songs/videos I try to play. The worst thing, is that after a while I can't go trough the search folders and therefore, I can't look for new songs.
I hope that you can understand my problem... I tried being as clear as possible. also hope to have your help fixing this problem.
Regards.
PS: My virtual DJ is 7.3 /I'm using a Numark NS6 / Mac OSX 10.7.5 / Intel HD GRAPHICS 4000
Regards.
geposted Mon 16 Sep 13 @ 4:31 pm
i guess no answer in english ether ha
geposted Thu 26 Sep 13 @ 12:30 pm
The VDJ Mac System Requirements for video mixing are:
https://virtualdj.com/products/virtualdj/
The card you are talking about does only have sharded memory instead of dedicated memory!
If you own a MBP with two videocards, you have to activate the higher one for use only.
Quote :
> ATI™ or NVIDIA® video chipset w/256MB of Dedicated DDR3 RAM
> Video must support dual-screen output
geposted Fri 27 Sep 13 @ 1:48 am
