Forum: Old versions
Topic: Question Mapping a Korg nanoKontrol2: active effect toggle
Hello all, I'm pretty new to the software and this is my first post so bear with me.
Basically, my first question is about assigning a button that functions as an on/off switch for each deck's active effect. After having searched through the forums, I figured some stuff out but not enough.
Using this action: <deck 1 effect active on> I have been able to press the assigned button to turn the effect on, however cannot afterwards turn it off with another press.
Using this action: <deck 1 effect active toggle> I have been able to press the button and turn the effect on only while it was pressed. Upon the button's release, it goes off.
I know I'm pretty close lol.
Could anyone point me in the right direction? I'd love to get this figured out before my trial expires lol.
geposted Mon 23 Sep 13 @ 12:02 am
you just leave the on part out of it and it will default to toggling the effects activation.
deck 1 effect active // this activates the main effect. If you only have one slot on your skin it's that one
deck 2 effect 'effectName' active //this activates the effect by name
deck 1 effect 3 active // this activates the effect slots
you can also use things like
deck 1 effect slider 1 // if your using the keyboard you can increment by putting + or - at the end with a percentage/decimal value eg. "deck 1 effect slider 1 +1%" or "deck 1 effect slider 1 +0.01" both are the same just written differently
deck 2 effect button 1 1 // the first number is the button you want to push, the second number is binary for on
https://virtualdj.com/wiki/VDJscript_verbs.html
https://virtualdj.com/wiki/VDJscript.html
Thank you very much!
Thank you so so much :)
