Hi,
I am writing a VD plugin that s got a Win Tab Control on it. The problem it never select tabs other than the first one when you click on them. I don t thinks it has something to see with the code as it works fine when I launch the window independently (I mean not as a VD plugin but a standalone application).
I am so struggling to find what did I do wrong. If someone could help, I would be greatfull.
I paste here the code of main windows (on the plugin side, I use createwindow and pass the hwnd to VD as advised in the VD plugin doc):
Thanks
#include "DJ4Me_gui.h"
LRESULT CALLBACK DJ4Me_gui::WindowProc(HWND hwnd, UINT uMsg, WPARAM wParam, LPARAM lParam)
DJ4Me_gui* This = (DJ4Me_gui*)GetWindowLongPtr(hwnd,GWL_USERDATA);
switch (uMsg)
case WM_DESTROY:
PostQuitMessage(0);
return 0;
case WM_PAINT:
PAINTSTRUCT ps;
HDC hdc = BeginPaint(hwnd, &ps);
FillRect(hdc, &ps.rcPaint, (HBRUSH) (COLOR_WINDOW+1));
EndPaint(hwnd, &ps);
return 0;
case WM_NOTIFY:
HWND tab = This->_tabBox;
HWND sender = (HWND)lParam;
int selectedTab = TabCtrl_GetCurSel(tab);
wchar_t buffer[256];
wsprintf(buffer, L"%d", selectedTab);
switch (((LPNMHDR)lParam)->code)
case TCN_SELCHANGING:
// Return FALSE to allow the selection to change.
return FALSE;
case TCN_SELCHANGE:
MessageBox(0,buffer, L"Title", MB_OK);
switch ( selectedTab ) {
case 0: if ( This->_tab1 == This->_currentTab ) break;
ShowWindow(This->_currentTab, SW_HIDE);
ShowWindow(This->_tab1, SW_SHOW);
This->_currentTab = This->_tab1;
break;
case 1: if ( This->_tab2 == This->_currentTab ) break;
ShowWindow(This->_tab2, SW_SHOW);
This->_currentTab = This->_tab2;
break;
return DefWindowProc(hwnd, uMsg, wParam, lParam);
DJ4Me_gui::DJ4Me_gui(HINSTANCE hInstance)
this->the_instance = hInstance;
init_win(hInstance);
this->create_toolbar();
this->create_tabBox();
this->create_listbox();
this->resize();
SetCursor(LoadCursor(NULL, IDC_ARROW));
SetWindowLongPtr(the_handle, GWL_USERDATA, (LONG)this);
int DJ4Me_gui::init_win(HINSTANCE hInstance)
// Register the window class.
const wchar_t CLASS_NAME[] = L"dj4me_gui";
WNDCLASS wc = { };
wc.lpfnWndProc = WindowProc;
wc.hInstance = hInstance;
wc.lpszClassName = CLASS_NAME;
RegisterClass(&wc);
// Create the window.
HWND hwnd = CreateWindowEx(
0, // Optional window styles.
CLASS_NAME, // Window class
L"Learn to Program Windows", // Window text
WS_OVERLAPPEDWINDOW, // Window style
// Size and position
CW_USEDEFAULT, CW_USEDEFAULT, CW_USEDEFAULT, CW_USEDEFAULT,
NULL, // Parent window
NULL, // Menu
NULL, // Instance handle
NULL // Additional application data
if (hwnd == NULL)
return 0;
the_handle = hwnd;
return 1;
int DJ4Me_gui::show()
ShowWindow(the_handle, 5);
// Run the message loop.
MSG msg = { };
while (GetMessage(&msg, NULL, 0, 0))
TranslateMessage(&msg);
DispatchMessage(&msg);
return 1;
int DJ4Me_gui::create_toolbar()
HIMAGELIST g_hImageList = NULL;
// Declare and initialize local constants.
const int ImageListID = 0;
const int numButtons = 3;
const int bitmapSize = 16;
const DWORD buttonStyles = BTNS_AUTOSIZE;
// Create the toolbar.
HWND hWndToolbar = CreateWindowEx(0, TOOLBARCLASSNAME, NULL,
WS_CHILD | TBSTYLE_WRAPABLE, 0, 0, 0, 0,
the_handle, NULL, the_instance, NULL);
if (hWndToolbar == NULL)
return NULL;
// Create the image list.
g_hImageList = ImageList_Create(bitmapSize, bitmapSize, // Dimensions of individual bitmaps.
ILC_COLOR16 | ILC_MASK, // Ensures transparent background.
numButtons, 0);
// Set the image list.
SendMessage(hWndToolbar, TB_SETIMAGELIST,
(WPARAM)ImageListID,
(LPARAM)g_hImageList);
// Load the button images.
SendMessage(hWndToolbar, TB_LOADIMAGES,
(WPARAM)IDB_STD_SMALL_COLOR,
(LPARAM)HINST_COMMCTRL);
// Initialize button info.
// IDM_NEW, IDM_OPEN, and IDM_SAVE are application-defined command constants.
TBBUTTON tbButtons[numButtons] =
{ MAKELONG(STD_FILENEW, ImageListID), IDM_NEW, TBSTATE_ENABLED, buttonStyles, {0}, 0, (INT_PTR)L"New" },
{ MAKELONG(STD_FILEOPEN, ImageListID), IDM_OPEN, TBSTATE_ENABLED, buttonStyles, {0}, 0, (INT_PTR)L"Open"},
{ MAKELONG(STD_FILESAVE, ImageListID), IDM_SAVE, 0, buttonStyles, {0}, 0, (INT_PTR)L"Save"}
// Add buttons.
SendMessage(hWndToolbar, TB_BUTTONSTRUCTSIZE, (WPARAM)sizeof(TBBUTTON), 0);
SendMessage(hWndToolbar, TB_ADDBUTTONS, (WPARAM)numButtons, (LPARAM)&tbButtons);
// Resize the toolbar, and then show it.
SendMessage(hWndToolbar, TB_AUTOSIZE, 0, 0);
ShowWindow(hWndToolbar, TRUE);
_toolBar = hWndToolbar;
return 1;
int DJ4Me_gui::create_tabBox()
HWND hwnd = CreateWindowEx(NULL, WC_TABCONTROL, NULL,
WS_CHILD | WS_VISIBLE,
0,0,0,0,
the_handle, NULL,
if (hwnd == NULL)
return NULL;
// Create two tabs.
TCITEM tab_info;
//memset(&tab_info, 0, sizeof(tab_info));
tab_info.mask = TCIF_TEXT;
tab_info.pszText = L"Available Songs";
tab_info.cchTextMax = 25;
SendMessage(hwnd, TCM_INSERTITEM, 0, (LPARAM)&tab_info);
tab_info.pszText = L"Requests Queue";
SendMessage(hwnd, TCM_INSERTITEM, 1, (LPARAM)&tab_info);
// Create the tab view windows
_tab1 = CreateWindowEx(NULL, L"STATIC", L"",
WS_CHILD | WS_VISIBLE|SS_OWNERDRAW,0,0,0,0,hwnd, (HMENU)1, the_instance, NULL);
SetParent(_tab1, the_handle);
_tab2 = CreateWindowEx(NULL, L"STATIC", L"",
WS_CHILD|SS_OWNERDRAW,0,0,0,0,hwnd, (HMENU)2,the_instance, NULL);
SetParent(_tab2, the_handle);
_tabBox = hwnd;
ShowWindow(_tab2, SW_HIDE);
ShowWindow(_tab1, SW_SHOW);
_currentTab = _tab1;
return 1;
int DJ4Me_gui::create_listbox()
HWND hwnd = CreateWindowEx(WS_EX_CLIENTEDGE, L"Listbox", NULL,
WS_CHILD | WS_VISIBLE | WS_VSCROLL |
LBS_DISABLENOSCROLL | LBS_SORT,
0, 0, 0, 0, _tab1, (HMENU)11,
if (hwnd == NULL)
return NULL;
_listBox1 = hwnd;
SendMessage(hwnd, LB_ADDSTRING, 0, (LPARAM)L"Martyn.Rae");
0, 0, 0, 0, _tab2, (HMENU)11,
if (hwnd == NULL)
return NULL;
_listBox2 = hwnd;
SendMessage(hwnd, LB_ADDSTRING, 0, (LPARAM)L"Alou.seck");
return 1;
int DJ4Me_gui::resize()
//Getting the toolbar size
RECT rect;
GetClientRect(_toolBar, &rect);
int height_t = rect.bottom - rect.top;
//Getting the windows size
GetClientRect(the_handle, &rect);
int width_tb = rect.right - rect.left;
int height_tb = rect.bottom - rect.top;
SetWindowPos(_tabBox, NULL,0, height_t, width_tb, height_tb - height_t,SWP_SHOWWINDOW);
//Getting the tab size
GetClientRect(_tabBox,&rect);
SendMessage(_tabBox, TCM_ADJUSTRECT, FALSE, (LPARAM)&rect);
SetWindowPos(_tab1,NULL, rect.left , rect.top + height_t , rect.right - rect.left, rect.bottom - rect.top,SWP_SHOWWINDOW );
SetWindowPos(_tab2,NULL, rect.left, rect.top + height_t , rect.right - rect.left, rect.bottom - rect.top,SWP_SHOWWINDOW );
//Getting the tab1 size
GetClientRect(_tab1,&rect);
SetWindowPos(_listBox1, NULL, rect.left, rect.top, rect.right - rect.left, rect.bottom - rect.top, SWP_NOMOVE|SWP_NOZORDER );
GetClientRect(_tab2,&rect);
SetWindowPos(_listBox2, NULL, rect.left, rect.top, rect.right - rect.left, rect.bottom - rect.top, SWP_NOMOVE|SWP_NOZORDER );
return 1;
Thanks
switch (uMsg)
case WM_DESTROY:
PostQuitMessage(0);
return 0;
case WM_PAINT:
PAINTSTRUCT ps;
return 0;
case WM_NOTIFY:
return FALSE;
case TCN_SELCHANGE:
break;
break;
this->resize();
WNDCLASS wc = { };
RegisterClass(&wc);
NULL, // Menu
if (hwnd == NULL)
return 0;
the_handle = hwnd;
return 1;
MSG msg = { };
return 1;
return NULL;
numButtons, 0);
// Add buttons.
return 1;
0,0,0,0,
the_handle, NULL,
if (hwnd == NULL)
return NULL;
// Create two tabs.
TCITEM tab_info;
_tabBox = hwnd;
return 1;
if (hwnd == NULL)
return NULL;
_listBox1 = hwnd;
if (hwnd == NULL)
return NULL;
_listBox2 = hwnd;
return 1;
RECT rect;
return 1;
geposted Tue 24 Sep 13 @ 1:21 pm
No reason a tab control wouldn't work; I've used them in plugin windows in the past.
What does your tracing show when you follow the message flow?
geposted Tue 24 Sep 13 @ 4:03 pm
In the message handling process, I try to show the selected tab by:
It shows the expected behavior when run as standalone app. But shows always 0 when run as VD plugin. I have not no idea about why.
geposted Tue 24 Sep 13 @ 4:14 pm
