I'm pretty sure VirtualDJ used to support Serato creates both in the Music library and on USB sticks.
This no longer seems to be the case. I'm using the latest version of Serato DJ and Virtual DJ v7.4.
I'm not exactly sure when this feature stopped becoming available. Does anyone know if it can be restored?
Thanks!
Thanks!
geposted Tue 08 Oct 13 @ 9:44 pm
Serato Crates are still supported. The Crates need to be under the MyMusic Folder (_Serato_ subfolder)
That was the case before the new Serato dj software came though.
This might help you... https://virtualdj.com/homepage/cesarcastillo/blogs/4657/How_To_Import_And_Read_Serato_Crates_In_Virtual_DJ.html
geposted Tue 08 Oct 13 @ 10:29 pm
is there any tutorial about how to setup sl1 and vdj?
geposted Wed 15 Jan 14 @ 3:41 pm
You just set it up like you would with SSL. It is an old card though, you'd be better off replacing it with an SL2, SL3 OR SL4 as the all sound waaaaay better then the SL1.
geposted Wed 15 Jan 14 @ 10:16 pm
