Forum: VirtualDJ Plugins
Topic: filter_sbdj - Page: 1
Hi all,
Just added a new filter effect for PC & Mac users.
It's nothing fancy, just a very simple decent sounding (IMHO) filter.
It has a single frequency slider, and a few buttons:
Reset: Resets filter to 50% (ie no filter)
Preset 1-4: Recall preset positions
Save: When enabled the preset buttons will save rather than recall
http://www.virtualdj.com/addons/16287/filter_sbdj.html
Map a knob to something like this:
effect 'filter_sbdj' active on & effect 'filter_sbdj' slider 1
Regards,
Scott
geposted Wed 16 Oct 13 @ 7:06 pm
Thank you Scott!!
Downloading now!
interesting to play with already. just clicking back and forth on the presets after a quick save and instantly made windows vibrate. niiiice.
that sounds really nice Scott! not sure why the presets are needed though?
They aren't really IMHO; they were just something someone asked for during testing. Since it was 30 seconds to add them I did it anyway!
For anyone wanting to use this as a filter replacement, say on a controller filter knob:
effect select "filter_sbdj" & param_greater 49% ? param_smaller 51% ? effect "filter_sbdj" active off : effect "filter_sbdj" slider 1 & effect "filter_sbdj" active on : effect "filter_sbdj" slider 1 & effect "filter_sbdj" active on
That will control the filter, and deactivate it when the filter knob is centered. It will however change the currently selected effect to the filter. If you wish to avoid this, try:
effect 9 select "filter_sbdj" & param_greater 49% ? param_smaller 51% ? effect 9 active off : effect "filter_sbdj" slider 1 & effect 9 active on : effect "filter_sbdj" slider 1 & effect 9 active on
The 9 is just a spare effect slot that probably isn't used on most skins.
On skins with a single effect slot - like the default skins - you may find the skin changes the effect to the filter. You can fix this by changing the skin slightly.
Change %maineffect in the skin to %effectslot1
Then change all the effect commands to use slot 1, for example:
Change "deck 1 effect active" to "deck 1 effect 1 active"
Change "deck 2 effect active" to "deck 2 effect 1 active"
Change "deck 1 effect select" to "deck 1 effect 1 select"
Change "deck 2 effect select" to "deck 2 effect 1 select"
Change "deck 1 effect slider 1" to "deck 1 effect 1 slider 1"
Change "deck 1 effect slider 2" to "deck 1 effect 1 slider 2"
Change "deck 2 effect slider 1" to "deck 2 effect 1 slider 1"
Change "deck 2 effect slider 2" to "deck 2 effect 1 slider 2"
Skins with multiple slots aren't likely to be effected as they will already be using numbered slots.
Greetings SBDJ ... As might assign this effect to the filter knob for pioneer ddj sx? I mean remove the default filter and put this in place.
Thanks Scott, it sounds great.
nice one SB!...
SBDJ, very nice filter!
Can you make another version of the same filter where the slider will be controlled by effect slider 2 instead of effect slider 1?
Just to add that I've used this at the weekend for a gig and it sounded great. Thanks :-)
Great but, can you put some resonance?
Updated to v1.1.
A few minor tweaks and the addition of controllable resonance.
dead link! can't download windows version
Awsome! link fixed yet?
Link working fine here?
Thanks for follow my advices SB, in time to time has a little distortion depending the resonance slider, anyway it's a great plugin
v1.2 now available rather quickly as I noticed a memory leak I introduced into v1.1. This version fixes that and also brings with it a tiny performance improvement.
....cant download... says server redirected?....
Edit:...mac bundle link works but not windows?
synth...did you just say something? (need to drop a level bro)... dancing on top off my new double pedalboard must of done something to system.feel like I've been before...hmm...you know?
59%
