Hello!
Is there a possibility to set up keyboard shortcuts to increase and decrease BPM by 0,1?
I have been looking around and all i can do is set up % or else... when i simply want to pass from 120,1 to 120,2 for instance :)
Thanks in advance for your help.
Cheers
Cheers
geposted Thu 17 Oct 13 @ 7:10 am
You can assign keyboard shortcuts to pitch +0.1 / pitch -0.1 or even smaller values such as pitch +0.01 / pitch -0.01
However, because pitch is a percentage, its actual affect on the BPM of the song will depend on the pitch range you are using and the original BPM of the song. It's not currently possible to map a shortcut that adjusts pitch in a manner so that the BPM increases/decreases exactly by 0.1
geposted Thu 17 Oct 13 @ 7:43 am
