Forum: Old versions
Topic: Multi Instance help
Hello.
Im trying to open 2 instances of virtualDJ but its not happening for me at the moment. Is there something i need to enable to achieve this??
The reason i need to do this is thus..
https://virtualdj.com/forums/180882/VirtualDJ_Skins/VirtualTouch_ver_1_1_(4_3_ratio)_skin_engine_glitch.html
Occasionally the browser appears with white bands and is un-readable. im not sure why this happens and i cannot predict when this will happen as 75% of the time i can get through a gig without this happening.
My workaround is that i want to create a multi-instance skin co that i can have 2 decks on standby on screen ready to take over should this browser glitch arise. (then i can safely re-start virtualdj without spoiling the flow)
geposted Mon 21 Oct 13 @ 5:58 pm
I believe this won't work since we can have have 99 decks now. I could be wrong but when 7 was released they did away with the multi instance.
did you try changing the skin then changing it back? you can probably just click on the same skin to refresh it, that's all you do when you are making a skin... other than that I would look at updating or reinstalling your graphic card drivers.
Multi-instance is not available.
I replied to your other thread as well. Driver/Graphics card related imo.
Do you have the skin in maximized mode when this happens ?
Ive replied in the other post to you DJDad
changing TO this skin and FROM it results in a 1 second audio drop out.
as ive mentioned in the skin forum, everything is up-to-date and the windows install is recent and clean. however i'll keep an eye on this as the graphics driver updated recently.
The audio dropout usually only happens when changing to a different number of decks.
If you change from a 4 deck to a 4 deck skin there should be no problem.
Keith
