Hi I just downloaded and installed the 16 band eq from the plug ins and it seems to be what i'm looking for but is there any way of making it stay active when loading a new song? I can save and load presets fine but it's not much good if I need to activate it every time I load a new song?
I also tried the 32 band but same result
Thanks
Thanks
geposted Wed 23 Oct 13 @ 4:46 am
There is an option to disable reset fx on load in config - options.
geposted Wed 23 Oct 13 @ 2:32 pm
