Hey,
I installed VDJ 7.0.2 and once I get over the configuration of the outputs and the soundcard and press "apply" I get a crashguard error.
Here's the report:
Crash ID=04aa8dcb (date=1310252308, version=7.0.2 LE, build=353, thread=Main, dump=8b088b51, excode=c0000005 (0,0))
Crash ID=04098dcb (date=1310252309, version=7.0.2 LE, build=353, thread=Main, dump=8b088b51, excode=c0000005 (0,0))
Crash ID=03fd8dcb (date=1310252310, version=7.0.2 LE, build=353, thread=Main, dump=8b088b51, excode=c0000005 (0,0))
Crash ID=03f38dcb (date=1310252310, version=7.0.2 LE, build=353, thread=Main, dump=8b088b51, excode=c0000005 (0,0))
Crash ID=03bf8dcb (date=1310252317, version=7.0.2 LE, build=353, thread=Main, dump=8b088b51, excode=c0000005 (0,0))
Crash ID=04df8dcb (date=1310252323, version=7.0.2 LE, build=353, thread=Main, dump=8b088b51, excode=c0000005 (0,0))
Please, help.
Here's the report:
Please, help.
geposted Fri 25 Oct 13 @ 9:27 pm
PS: I also went to chet the software updates for the Typhoon I'm using and it says that the latest version to it is the 7.0.2, not the 7.0.3 as I read in other posts.
Thankyou.
Thankyou.
geposted Fri 25 Oct 13 @ 9:29 pm
This is most likely a problem with the Typhoon sound driver. Please see https://virtualdj.com/wiki/Typhoon.html
NOTE: The most recent version of VirtualDJ LE for your controller will be shown in your Download Center. VirtualDJ LE is limited software and is not normally eligible for free updates to the latest version unless the manufacturer has made special arrangements.
To be able to use the latest version of the software (Strongly recommended), you can upgrade to the full VirtualDJ Pro at a discount. You can try it out for 10 minutes at a time before upgrading by downloading and using the latest VirtualDJ Home FREE. Please note that old versions of the software are no-longer debugged by the development team.
geposted Sat 26 Oct 13 @ 11:07 am
