Forum: Old versions
Topic: Controller latency
Hi,
I´m using KAM DIGI TWO controler and Virtual DJ 7.4. I am challenging the problem with latency after quick fade out/fade in (when I move channel level to zero and back to max). I have a feeling, it´s about 0,5 to 1 sec = definitely I can´t catch exactly the beat I want.
Does anybody knows the solution?
I have standard drivers installed. Do You think that ASIO pack would help me?
Thank You
geposted Mon 04 Nov 13 @ 6:36 pm
The Kam Digi Two does not have or require an ASIO driver. It operates with the standard Windows WDM driver (plug & play).
geposted Mon 04 Nov 13 @ 6:52 pm
So don´t You know if there is some solution for my problem? Thanks
geposted Mon 04 Nov 13 @ 7:00 pm
My suggestion would be buy a better controller!
geposted Mon 04 Nov 13 @ 7:17 pm
