Forum: Old versions
Topic: [OSX 10.9 Mavericks] crash on startup resolved
Today is been released Virtualdj 7.4.1.
it's small maintenance release for VirtualDJ 7
This release fix also the problem of crash on startup in OSX 10.9 Mavericks.
the update is free for the registered users of Virtualdj pro full, pro basic and brodcaster:
https://virtualdj.com/download/updates.html
The full changelog is available here
geposted Thu 14 Nov 13 @ 8:10 am
"Today is been released"
What does that even mean?
This means it is available now.
Just check your download center. :-)
Hello...i can't download this update because i havent got a license. I installed the Virtual home DJ But where i can find a l;icense, since the software crashes on loading...?
This mean the laggy waveforms & nearly crashing beat grid change while live mixing FIXED?
New Macbook Air 2013 and was slow and everything wasnt impressed!
First program to use and only! Pro DJ
Will this update fix this? or the i5 & 4GB not run virtual dj
Why hasn't Atomix updated those with Virtual DJ LE for the Numark DJ2Go? I'm still sitting at 7.4 and I need a fix.
cpiotrowski92 wrote :
Why hasn\'t Atomix updated those with Virtual DJ LE for the Numark DJ2Go? I\'m still sitting at 7.4 and I need a fix.
https://virtualdj.com/wiki/VirtualDJ%20Controllers.html That numark Dj2go is a nice controller,VDj made a Skin/Software made for that controller LE.Computer are getting more advancing and that why VDJ have VDJ-Pro to keep you updated with your computer.If you using the Dj2go to do your gigs try getting a computer that has W7 32bit & just used that for your Dj gigs.( I have W7 and version 10.6.8 Mac with N/p ) The pro with Karaoke scratch v2.3.1 skin and DEEjay Trim 4&6
asthedj wrote :
[quote=cpiotrowski92]Why hasn\'t Atomix updated those with Virtual DJ LE for the Numark DJ2Go? I\'m still sitting at 7.4 and I need a fix.
VirtualDJ LE is limited software and is not normally eligible for free product updates.
Please see our FAQ pages: https://virtualdj.com/wiki/Can%20I%20upgrade%20to%20the%20latest%20version%20of%20VirtualDJ.html
If you would like to use the latest version as well as all features of the software, then you can upgrade to the full VirtualDJ Pro: https://virtualdj.com/buy/
I am unable to open the download of VDJ 7 pro on macbook pro version OSX 10.9.1
