Hi, can sombody help me write a script to emulate the crossfader trigger effect on the Pioneer DJM3000??
Effect Mix Fader Mode
1 Using the CROSS FADER ASSIGN switches (A
and B) choose the channel (CH1–CH4) connected
to the CD player you wish to use with cross fader
effects.
¶Be sure to assign different channels to the CROSS
FADER ASSIGN switches A and B.
2 Set the CROSS FADER CURVE selector switch to
1 ( ).
¶ When set to 2 or 3, the sound volume will become
lower depending on the setting of the Cross fader lever.
3 Set the Cross fader lever to the Effect Mix
starting position.
In the Effect Mix Fader mode, the way the sound is
initially heard is determined by the starting position of the
Cross fader lever. For operating procedures, see step 6.
¶ When the Cross fader lever is near the midway point,
sound will be output from both A and B.
¶ When the Cross fader lever is on the A side, sound will
be output from A.
¶ When the Cross fader lever is on the B side, sound will
be output from the B side.
4 Set EFFECT MIX selector switch to FADER.
¶ Of the three Effect select/start switches (ECHO, ZIP,
ROLL), the selected one will flash (default setting is
ECHO), and the others will light steadily.
¶The FADER START switch for the assigned channel will
automatically turn ON and its indicator will light.
If the settings of the CROSS FADER ASSIGN switches A/
B are changed after setting the EFFECT MIX selector
switch to FADER, the corresponding channel’s FADER
START switch will automatically turn ON.
5 Use the Effect select/start switches to choose
the desired effect (ECHO, ZIP, ROLL).
¶The selected Effect select/start switch will flash and
¶Two or more effects cannot be selected at the same
time.
¶The BEAT EFFECT’s effect PARAMETER controls can
be used to modify the effect time settings.
6 Operate the Cross fader Lever
¶ When the Cross fader lever is moved from side A
toward side B, the selected effect is applied to A, and
when the lever reaches side B, the B output sound is
heard. If the lever is returned to side A from midway,
the effect applied to A turns OFF and the normal sound
is output.
¶ When the Cross fader lever is moved from side B
toward side A, the selected effect is applied to B, and
when the lever reaches side A, the A output sound is
heard. If the lever is returned to side B from midway,
the effect applied to B turns OFF and the normal sound
is output.
[Operation if Cross fader lever is midway when the
Effect Mix Fader mode is turned on]
¶ When the Cross fader lever is moved from its initial
midway position toward side A, the selected effect is
applied to B, and the sound will progressively turn off in
accordance with the selected effect.
midway position toward side B, the selected effect is
applied to A, and the sound will progressively turn off in
¶In the Effect Mix Fader mode, the Cross fader lever cannot be
used to control sound. While the CROSS FADER CURVE
selector switch is enabled, BEAT EFFECTS cannot be used.
effects.
1 ( ).
starting position.
be output from A.
time.
is output.
is output.
geposted Fri 22 Nov 13 @ 11:40 am
