Forum: Old versions
Topic: Delay cut off
Greetings. I have been enjoying the Virtual DJ software for use with my behringer bcd 2000. but one very important function is lacking for me with my current software set up.
When I turn off the echo (delay) effect it cuts off immediately. Is there any way to have the effect continue when I pause the track or turn off the effect, like a slow fade out of the effect, it sounds so sudden and messes up the mood of the mix to cut it off immediately.
geposted Sat 23 Nov 13 @ 12:27 pm
If you upgrade to the pro version, you will have access to more effects, including echo out and loop out. However, all effects end when you stop the track.
