Forum: Old versions
Topic: HELP MAPPING
Basically im tyring to map my LPD8 for effects in VDJ, basically ill click pad 1 on deck A and the effect works for deck A , i click pad 1 on deck B and the effect works for deck B.
Now the hard part.. on my LPD8 becuase it hasnt got a deck A and deck B just one joint deck if you like, how do i map it so the effect plays on both decks at the same time, because at the moment the effects only work on the side i last loaded a song on :/ !
This is wat i have typed in for my CONTROLLER not my LPD8 and works on each deck -
var $shift ? deck 1 sampler default select 1 & deck 2 sampler default select 1 & sampler 1 play_stop : effect "Beatgrid" active while_pressed
I have a gig tommorrow so any help would be lovely :D
geposted Thu 28 Nov 13 @ 6:25 pm
deck 1 effect "Beatgrid" active while_pressed & deck 2 effect "Beatgrid" active while_pressed
I hope this was in time
