Considering the lack of skins that offer multiple Effect slots and the newly added midi controllers that offer this (such as the DDJ-SX and the upcoming DDJ-SR, DDJ-SP1 and NS7 II), i thought i should make a modification of the AIO 4 Decks skin.
So here it is ..
VirtualDJ 7 (4 Decks) MultiFX HD
Download Link : http://www.virtualdj.com/addons/16374/VirtualDJ_7_(4_Decks)_MultiFX_HD.html
HD Resolutions : 1600x900, 1920x1080
Video Support
3 different Video Views in VIDEO Panel (Rightclick on the VIDEO panel button)
4 or 8 HotCues with various infos such as CueName, CueTime, CuefromTime, BeatsFromCue.
and of course Single and Multi Effects Panels, which offer effects for all decks individually or Left-Right Decks..
the skin is also offering a 4rth panel in the center with useful options, such as changing the mixer Channel Order from 1-2-3-4 to 3-1-2-4 (default)
Most of the panels change based on variables (which are also used in several default mappers), so its easy to apply to your own custom mapper as well.
Have fun !
PS. Please dont ask for additional resolutions. Use the Resizer Tool.
PS2. A 2 decks version, following the same logic will come soon.
So here it is ..
Video Support
Have fun !
geposted Sat 30 Nov 13 @ 1:11 am
.... which will look like this ...
 MULTIFX 1920.jpg)
geposted Sat 30 Nov 13 @ 3:13 am
Wow, excellent work Babis. Looking forward to the 2 deck one!
Keith
Keith
geposted Sat 30 Nov 13 @ 3:38 am
truly spectacular wonderful
especially the video area
geposted Sat 30 Nov 13 @ 3:39 am
Ooooohh yesss,were getting ready for da Big BANG!...he,he...as some allready know...I LUV Effects! :p
geposted Sat 30 Nov 13 @ 3:57 am
Wow, great work ;o)
geposted Sat 30 Nov 13 @ 11:19 am
Wonderful! I will try it later. Hopefully soon useable with the 'Hammer' DDJ-SR!
Thanks a lot for your work and
always happy Djing ;-)
The PARTYGENTLMEN (.de)
geposted Sat 30 Nov 13 @ 11:51 am
excellent !! Bravo !!
geposted Sat 30 Nov 13 @ 1:46 pm
wow perfect skin..!!! can yo do in 1376*768??? djdad?? in 2 decks please..!!
+1
+1
geposted Sat 30 Nov 13 @ 1:47 pm
@DJ Potter:
geposted Sun 01 Dec 13 @ 5:40 pm
+1
+1
geposted Sun 01 Dec 13 @ 5:47 pm
+1
+1
Potter, i ll release the 2 decks version, if you change your avatar too :P I ts not good to copy other's work ;)
geposted Sun 01 Dec 13 @ 6:12 pm
I love Skins 2 Decks, heed potter :-)
geposted Sun 01 Dec 13 @ 6:18 pm
2 Decks version is now available.
VirtualDJ 7 (2 Decks) MULTIFX HD
Download Link : http://www.virtualdj.com/addons/16379/VirtualDJ_7_(2_Decks)_MULTIFX_HD.html
Similar features to the 4 deck version.
Resolutions : 1600x900 & 1920x1080
geposted Tue 03 Dec 13 @ 12:09 am
Will it be good enough to replace the beloved TCMania 2.2 though? Will find out tonight......
geposted Tue 03 Dec 13 @ 1:41 am
Yep, the 2 deck version is very nice indeed in 1920x1080. Thanks Babis!
Keith
Keith
geposted Tue 03 Dec 13 @ 3:25 pm
very good skin (2 decks).
geposted Wed 04 Dec 13 @ 1:57 pm
tested the 4 deck version last nite,nice! but Im so used to having 6 cue points like in my RMX mod of Bruno's skin...with Stanton's SCS 3D in trgger mode you can go off!
geposted Wed 04 Dec 13 @ 2:44 pm
Hi Babis,
The High EQ kill buttons don't seem to work on the 2 deck skin 1920x1080. Can't see anything obvious in the XML
Keith
Keith
geposted Thu 05 Dec 13 @ 7:55 am
They work here. You dont get the action on the Tooltip when you move mouse over them ? What happens if you click on them ? Do they stay on ?
Are you using the Full or the Parametric Eq ? what are the values you are using ?
The High frequencies and Killls are offering a very short range of frequencies. To make sure that the Highs are killed, set the EQ to Full (from Options), then kill the Mids and the Lows. You should hear the Highs then ,After that, kill the Highs to see that it works ;)
geposted Thu 05 Dec 13 @ 12:56 pm
