I doubt this is possible at present but I think loop and loop roll should be separate entities
during breakdowns I use short loop rolls (1/8 to 2 beats) to build up the atmosphere but most breakdowns in tracks aren't long enough
What would be great is if you could set up a loop (lets say 128) and while you are in that loop you perform loop rolls, but the rolling return position should loop within the initial loop.
Also sort out reverse loops.
geposted Tue 03 Dec 13 @ 7:12 am
I was wondering what would happen (if this was possible) if you initiated a loop roll and then a loop (if it would cause problems), and I don't think it would, it would work, let's see what sandbox in V8 brings up.
geposted Tue 03 Dec 13 @ 11:07 am
