Forum: Old versions
Topic: MAPPING BOMBED
Hey there.Trying to map a few shortcuts on my laptop. Any help will be much appreciated.Thanks in advance.
1- One key to toggle settings window on and off...easy to get it on but gotta use mouse to get it off.
2- After searching and finding a song, wanna bypass right>click go to folder where the song is located..browser_gotofolder works but you still need to scroll if there are too many expanded folders. Does not bring the high lighted folder in view like how right click>go to folder does.
Just those to buggers...thanks again
geposted Tue 03 Dec 13 @ 1:35 pm
1. Action : settings , opens the CONFIG menu, but there is no action to close the window. and frankly i cant see the necessity of such an action, as most of time, when someone needs the CONFIG window, he will use the mouse after all, to change something.
2. browser_gotofolder is the only action you can use currently, and it doesnt bring up the song if not visible on the first screen. The action was made to do exactly what the name says.. to go to the folder that the song exists, most likely to offer you other songs of the same folder e.g. to play another one from the same album.
Appreciate your response..
