Forum: Old versions
Topic: VIRTUAL DJ LE 7.4
Hi there,
I have a DDJ Wego and used the 20-day trial. I want to continue to use Virtual DJ LE - NOT THE PRO VERSION but it wont let me configure sound settings. It only gives me the option to upgrade to PRO.
geposted Thu 05 Dec 13 @ 3:25 pm
VirtualDJ LE is limited software that's plug and play. It does not have or need any configuration options (These are a full Pro feature.)
If it's not working, then simply perform a clean re-installation of the software, then re-install VirtualDJ LE following the instructions in the user manual that came with the WeGo.
If you need any assistance, then please contact support: https://virtualdj.com/contact/
