Forum: Old versions
Topic: Hercules MK2 - strange headphones probelm
Hi,
I have a strange problem with headphones. Of course I plug headphones into the headphone output. Knob includes four options: deck A, deck B, mix and split. When I put knob I hear different RANDOM opportunities - one time when I put "mix" I can hear a song from deck A, another time I hear a song from deck B, and another time I do not hear anything. It's probably some technical problem, not software. Someone had something like this?
geposted Fri 06 Dec 13 @ 8:31 am
The "Mix" option is to hear both decks at the same time in your head phones.
If deck a is playing and also deck b you should hear both.
Also check your crossfader state. If it is all the way to the left you may just hear deck a even if you choose "mix".
But I'm not sure of that.
I know that "The "Mix" option is to hear both decks at the same time in your head phones." It is very difficult to describe my problem - that`s why i called it "strange". The problem is that I for example put knob into position "mix" I hear song from A, then I do not touch anything (crossfader or antything else) and 3 seconds later I put knob to position deck B and back to "mix" I hear a song from deck B or nothing... And when I put knob into "split" I hear anything on headphones... It must me some kind of hardware mistake... isn`t it?
That does really sound strange.
Are the "Cue" LEDs on (the ones between FX and Loop) if you want to pre listen?
No.
Any ideas???
