Hey folks, what does it mean when a video played in either deck is smooth-as-silk, but when when played in the Clipbank plug-in, it's herky-jerky? (a technical term).
Thanks,
Doug
Version 7.4 Pro user here ....
Thanks,
Doug
geposted Wed 11 Dec 13 @ 1:59 pm
Check out this thread... https://virtualdj.com/forums/95136/VirtualDJ_Plugins/Plugin_not_working__Controls_not_showing__DX_File_Missing_______Read_this_before_posting_____.html
Make sure you have all the current updates.
There could be a number of reasons but the above will be a good starting point.
What type of file are you running in clipbank, try converting a file to HD WMV if you are not already using that format and report back please on results.
geposted Wed 11 Dec 13 @ 3:32 pm
