Forum: Old versions
Topic: Using USB Mic
Is there a way you can use a USB Mic with VDJ pro along with the two channels
All i am trying to achieve is the record a radio program for rebroadcast which require a mic for talk over and a two channels for music.
I would like to control the MIC as well during the session
geposted Thu 12 Dec 13 @ 9:41 am
It is possible while using the latest Pro Full from our side!
To get the latest build, please register your serial under your profile:
https://virtualdj.com/users/edit.html
After that you can download your actual VDJ copy from here:
https://virtualdj.com/download/updates.html
If you didn't own a vaild serial, you can buy it here:
https://virtualdj.com/buy/
When you use two soundcards, like you do, you have to act like you can see here:
https://virtualdj.com/wiki/Recording%20your%20set%20or%20broadcasting%20when%20using%20an%20external%20DJ%20mixer.html
