So after replacing the old CPU (Intel i5) in my system, my VDJ started to have this strange stuttering when I hover over any of the interactive elements (Timebar, Tables, Search bar) the mouse is heavily stuttering and the general FPS is going down.
I used google and found several people with the same problem, but none of the proposed solutions could fix my problem.
Anything else I might have missed?
It could be also the operation system, since I replaced my motherboard and my CPU and thus had to reinstall it.
geposted Tue 17 Dec 13 @ 11:44 am
which Hardware and OS exactly.....and of course....which Version of VDJ ( see at Config/ Info
Or just a post at the german forum...;-)
geposted Tue 17 Dec 13 @ 12:10 pm
My OS is Windows 7 and im using Virtual DJ 7. I tried using it on an older Version aswell, but it's the same problem. The CPU is an intel i5 4670k.
Things I already tried:
-disabling integrated graphics
-tried different skins
-changed some values in the registry (was in a youtube tutorial)
Well I dont have a problem posting in English ^^
My PC is a 4GB with a strong graphics card. On my laptop everything runs fine, but I prefer mixing on my desktop at home.
geposted Tue 17 Dec 13 @ 1:13 pm
Ok neither do i...;-)
first of all you should upgrade your Version 7.? to the actual 7.4.1. It doesn`t make sense searching for issues with an old version.
then please check this : https://virtualdj.com/wiki/Common%20PC%20Performance%20Issues.html
geposted Tue 17 Dec 13 @ 1:30 pm
