Hi, I am from Argentina, sory for my bad english. I just bought the Numark Mixtrack in the USA. My problem is that when I play music (for 10/15 minutes), Virtual Dj 7 starts getting stuck. For example, when I move the crossfader, or i scratch, or i apply an effect, the song cuts for like 10 seconds and then it returns to normal. If i continue mixing with other songs, Virtual DJ gets definitly stuck and i have to restart it.
I don´t think that this is due to the quality of my laptop, its a good one. At the end of the post i will leave screenshots of the system and all that shi*. Perhaps it is due to the fact that i have too many things connected at the time of using virtual dj (headphones, mixtrack, mouse, usb charger for the speakers), but when i use it only with the mouse connected it gets stuck all the same. When i pass the mouse over the plates the cursor starts cutting and the same happens with the song and the virtual dj visual elements.
Here is my computer data and how i configurate virtual dj 7:
http://screenshotuploader.com/s/1312qqcg1
http://screenshotuploader.com/s/1312lxvxi
http://screenshotuploader.com/s/1312602q7
http://screenshotuploader.com/s/1312afk4s
THANK YOU GUYS
THANK YOU GUYS
geposted Tue 17 Dec 13 @ 10:33 pm
please I need an answer fast!!
geposted Wed 18 Dec 13 @ 7:40 am
Are you using the latest download from your download center?
Have you tried it with just the Mixtrack alone?
Have you tried disabling the internet and closing anitvirus programs?
Have you checked for common performance issues?
https://virtualdj.com/wiki/Common%20PC%20Performance%20Issues.html
geposted Wed 18 Dec 13 @ 11:49 am
I´ve tried everything. I´ll leave you a short video that shows what happens. Thank you for answering.
geposted Wed 18 Dec 13 @ 12:51 pm
geposted Wed 18 Dec 13 @ 1:07 pm
A celeron processor is considered weak, and the Intel HD graphics card is also not the best choice to help with screen refreshing and skin graphics.
You will need to optimize your computer for better performance. https://virtualdj.com/wiki/Common%20PC%20Performance%20Issues.html
geposted Wed 18 Dec 13 @ 4:38 pm
thanks. Also when i activate an effect virtual dj gets stuck. Its for the same reason?
geposted Wed 18 Dec 13 @ 5:39 pm
Yes, exactly
geposted Wed 18 Dec 13 @ 6:35 pm
Ok. What would you recommend me to do? I have all the latest drivers and my notebook is programmed to work considering efficiency and not quality. There´s a chance that i can improve this problems without having to buy a new processor and graphic card?
geposted Wed 18 Dec 13 @ 7:03 pm
Colorado,
I already answer you on the spanish forum.
Check it please
Check it please
geposted Fri 20 Dec 13 @ 12:38 pm
