Forum: Old versions
Topic: Output Setup
Hi there, i just bought a numark (not pro version) and yes i bought the sound card that is needed to connect speakers and headphones.
The thing is that when im trying to hear the cue mix it also goes to my speaker, the mixtrack came with its own virtual dj software which is the LE version, and reading in other forums the option in output "external mixer" doesn't appear and im guessing that's the problem why i can't hear my cue mix. please help!!
geposted Wed 18 Dec 13 @ 6:27 pm
VirtualDJ LE is limited software and only supports master+headphone configuration (Using the MixTrack itself to control VirtualDJ's internal software mixer.) Please see: https://virtualdj.com/wiki/Pre-listening%20with%20headphones.html
If you wish to output both decks separately to an external hardware DJ mixer and use this to mix the songs instead of the MixTrack's built-in software MIDI mixer, then you will need to upgrade to the full VirtualDJ Professional at a discount: https://virtualdj.com/buy/
