Hi,
Expierienceing some popping, studdering.
What ASIO buffer settings should I try?
geposted Thu 19 Dec 13 @ 2:01 pm
high number should give clear sound if this is the problem but will give you a delay
geposted Fri 20 Dec 13 @ 1:24 am
Please ensure that your computer has been optimised for DJ performance. This should allow you to achieve a lower setting without any issues: https://virtualdj.com/wiki/Performance%20Issues.html
Once you have done this, set the buffer to the size where you get no sound break-up, stuttering, etc. (The correct setting will depend on your computer and its performance.)
geposted Fri 20 Dec 13 @ 6:28 am
