Forum: Old versions
Topic: OSX Mavericks Full Screen
Hi all,
I've had a little look through the forums to see if anyone else is having the same issue as me (I saw a thread regarding a separate issue)...
When I try to enter full screen on any HDMI device, the video takes over my laptop screen as opposed to the connected screen and if I exit out of the config I cannot do anything with VDJ as the damn video is in front of it!
Has anyone experienced this? Is it a simple fix? Usually it would be something pretty simple!
Cheers
Si
geposted Sat 21 Dec 13 @ 6:26 am
Well I haven't upgraded yet but in config under the video tab what do you have selected for your tv output??
In mavericks you don't have use the display settings on your MacBook. Just go to video in the VDB config and chlorose the correct screen. In mountain lion you had to change also the display settings on your MacBook .
So just connect you HDMI device and chlorose the correct screen within VDJ.
This workshop for me
In Mountain Lion you dont have to go into the Mac settings and change your display setting either UNLESS you want to change the resolution.........
