Hi,
When I want to record a mix the default file type is bin but I need it be to mp3. How can i change this? I've also checked and there doesn't seem to be any easy way to convert bin files to mp3.
Thanks in advance
Thanks in advance
geposted Fri 27 Dec 13 @ 9:09 am
bin files will be created if you choose BURN CD from the RECORD page of BROWSER.
mp3/wav files will be created if you choose RECORD AUDIO from the same page.
bin files are ready-to-burn files, used from applications like Nero
geposted Fri 27 Dec 13 @ 9:13 am
Ah, simple. Cheers dude
geposted Fri 27 Dec 13 @ 9:22 am
