I just bought a Numark NS6, and I would like the high EQ knob on all four channels to activate and control the filter using the effect "filter_sbdj". I have incredibly basic knowledge of mapping, so any help would be very appreciated.
geposted Fri 10 Jan 14 @ 12:31 am
Just try this action on the knob:
Frequency:
Resonance:
if the knobs need a specific deck:
Frequency:
Resonace:
Regards
Frequency:
effect 'filter_sbdj' slider 1
Resonance:
effect 'filter_sbdj' slider 2
Frequency:
deck 1 effect 'filter_sbdj' slider 1
deck 2 effect 'filter_sbdj' slider 1
Resonace:
deck 1 effect 'filter_sbdj' slider 2
deck 2 effect 'filter_sbdj' slider 2
Regards
geposted Fri 10 Jan 14 @ 1:59 am
You need to map all 4 Eq High knobs.
HIGH_1 -> var 'pcline1' ? nothing : effect 'filter_sbdj' active on & effect 'filter_sbdj' slider 1
HIGH_2 -> var 'pcline2' ? nothing : effect 'filter_sbdj' active on & effect 'filter_sbdj' slider 1
HIGH_3 -> var 'pcline3' ? nothing : effect 'filter_sbdj' active on & effect 'filter_sbdj' slider 1
HIGH_4 -> var 'pcline4' ? nothing : effect 'filter_sbdj' active on & effect 'filter_sbdj' slider 1
geposted Fri 10 Jan 14 @ 2:17 am
