Will I be able to broadcast my radio station, use cue features and my mic work live over my broadcast with Denon DNMC6000 board?
geposted Sat 11 Jan 14 @ 2:30 am
Yes.
geposted Sun 12 Jan 14 @ 5:41 am
Thanks for the response. Next questions what is a good mic to use when I'm broadcasting live on my streaming station?
I currently have a PV CARDIOID DYNAMIC, IT'S LOW IMPEDANCE.
geposted Tue 14 Jan 14 @ 10:05 pm
Just try the mic you have, and see how you get on.
Many people find the mic input on the mc6000 too "hot". This is more of a problem in a disco or club environment, and may not be an issue in a broadcasting situation.
Just give your mic a try.
geposted Fri 17 Jan 14 @ 4:49 pm
Hello. I'm running the Pro Version 7.4 with the Denon MC6000 controller. Overall it's working pretty well.
I have two questions:
1. I'm having a problem the FX's on the top of the screen and controller. When I try to activate any of them via the controller it does not seem to do anything or the song plays volume goes down.
When I click on the FX buttons on the screen of my PC using the mouse it seems to work ok, but when I use the Denon MC6000 controller itself nothing seems to happen.
2. Also, what the correct ISO driver that I should be using. I found two different ones. One is dated 9/21/13 and the second one is dated 10/04/13. Somehow they are both currently installed and displaying when I go into the windows control plan under programs and then programs and features.
Thanks.
david p. oesterle
Thanks.
david p. oesterle
geposted Fri 17 Jan 14 @ 6:01 pm
David,
for the first part: You can try an alternative mapping: https://virtualdj.com/addons/12744/DN-MC6000_Ch_3_1_L-R_2_4_Mapper.html
This works great for me.
The latest ASIO-driver is 2.22. The date doesn't really matter. If there was an updated version, it should have a higher revision-number.
http://www.dm-pro.eu/en/denondj/Products/Pages/ProductDetails.aspx?CatId=Controllers&SubCatId=Controllers&ProductId=DNMC6000ProfessionalDigitalMixerController , bottom, left side of the page.
geposted Sun 19 Jan 14 @ 2:46 pm
