I have a karaoke file that loses it's lyrics, they just disappear half way through the song. I played the original file on my desktop computer in VLC and it was fine, so I figured the one on my laptop was corrupted. I replaced the file on my laptop and it still lost the graphic part way through, so I made sure the file was deleted, cleaned and fixed my database, then added the replacement file, still no success. I renamed it v2 and put it in a separate v2 folder in case info was being retained by VDJ, no deal.
The file plays perfectly on VLC on my laptop also. Any ideas?
geposted Tue 14 Jan 14 @ 9:45 pm
I had an issue once where the automix was enabled on the video crossfader. So as i previewed the other deck crossfader would move over and swap video source.
I disabled the video crossfader Auto and Link options and then i manually move the fader across to the other deck!
If not that.... then i can't help sorry!
geposted Fri 17 Jan 14 @ 7:50 pm
OK, thanks. No, not that.
I'll purchase a replacement, different brand, just in case.
geposted Wed 22 Jan 14 @ 1:52 am
