in vdjpedia it Recommends : https://virtualdj.com/wiki/CDJ-400.html
Inputs: None
Outputs: External Mixer
Sound card(s): Two cards -> Choose the 1st CDJ400 sound card in first drop-down, and 2nd CDJ400 in the second drop-down.
Until now i use:
Inputs: None
Sound card(s): 4 out card
And everything was OK, Is There a difference between the settings ?
Inputs: None
Until now i use:
Inputs: None
geposted Sat 18 Jan 14 @ 4:28 pm
Someone ?
geposted Sat 01 Feb 14 @ 11:01 am
If it works that way for you, it means that either your Mac sees both CDJs as a single 4out Sound card or an aggregate device has been created to include both of them.
You can see how the CDJs are detected in Applications-->Utilities-->Audio Midi Setup
geposted Fri 07 Feb 14 @ 5:03 pm
im about to set mine up... just downloaded new skins.
im going to start making new skins but i dont think ill start now due to the fact that V8 is in BETA mode.
ill let you kno hows my set up
geposted Sun 09 Feb 14 @ 12:36 am
my settings is like yours.
i have used the asio settings but it was a while ago, i think i used that settings with ext sound card.
ok, just realised i was in mac thread, ill hook up my mac.
for some reason i don\'t have asio on mine anymore, strange.
my set up is like this on my MBP w/o sound card
geposted Sun 09 Feb 14 @ 12:43 am
i made an aggregate device with the pioneer App
geposted Mon 10 Feb 14 @ 12:24 am
@ pseft : Why do you use mono in your configuration ???
geposted Wed 12 Feb 14 @ 4:59 am
idk… i must of accidentally pressed it without knowing it
geposted Thu 13 Feb 14 @ 7:01 am
sorry for my english...
but... this configuration is not good i think
because you put all decks in mono
where is the stereo ?
you made one cdj in mono and otuer cdj in mono too
the stereo where is ? XD
for some reason i don\\\'t have asio on mine anymore, strange.
geposted Thu 13 Feb 14 @ 4:28 pm
This link can help you to configure your cdj's soundcards (on your mac you have to change your settings in the audio midi set up)
http://www.it.virtualdj.com/forums/125768/MAC_Version_Technical_Support/iMac___Pioneer_CDJ-400_VDJ_Soundcard_Configuration.html?search=%20span%20style=#20306317190158174800
geposted Mon 17 Feb 14 @ 12:54 pm
Never tried with the CDJ400, but i'm sure it will the same like with the others. :-P
1.Go the Pioneer download CDJ Aggregator for Mac
http://www.pioneer.eu/eur/support/software/CDJ-2000/page.html
2.Click on the download link CDJ Aggregator for Mac and confirm the download.
3.Connect both CDJss to your computer.
4.Go to your downloads folder and execute the file "CDJ_Aggregator".
5.If the connection has been successful, you will see the name of each of your CDJs in the CDJ Aggregator panel.
6.Open VDJ and there the soundcard config!
Input - None
Output - External Mixer
Soundcard - 4Out -- beside select the CDJ as the soundcard [Maybe shown as Pioneer CDJ (CoreAudio)]
Note: You will notice other drivers in the list called Pioneer CDJ-400 / 900 / 2000 (CoreAudio). Those are the individual drivers of each CDJ and should only be used with the particular device!
Input - None
geposted Tue 18 Feb 14 @ 7:49 am
Same way with cdj400 for Aggregator ;)
The 4Out souncard in vdj : going to try but i don't have this setting with the 400 ... (it works with 2 soundcards or advance audio config)
-->do you know what's the difference with 4out (best choice with vdj?) ???
geposted Tue 18 Feb 14 @ 5:05 pm
read my comment above yours...it clearly sez "IDK" which means "i don't know"
geposted Sun 23 Feb 14 @ 10:55 am
in osx 10.9 you cant change the names of the cdj 400 to 1-2 when you try to use this setup:
nputs: None
can i choose one sound card to be cdj 400 and the 2'nd the 400 aggregated device ?
if i work with two cdj's 400 do i need to check the drift correction ?
nputs: None
geposted Sun 06 Apr 14 @ 10:20 am
