Forum: Old versions
Topic: playlist total time plugin?
Heya, is there a plugin that can show the total time of a playlist? (much like windows media player and musicbee)
geposted Mon 20 Jan 14 @ 1:54 am
If you put all tracks in the auto-mix section you can see the total length of the tracks combined. Don't know if there's any sort of plugin to see it in an other list section.
Hi. I saw it once, but since then it just reads "Total" beside "AUTOMIX". Is there something I can do to make it appear again?
Thanks
I'm not at my PC right now so I can't check.
Is your side list slid over to far the the right for it to display?
I know this is visible with the default and Fruit skins.
should be there by default
How do I get to see this total length for a normal playlist?
Load the playlist in the automix window.
I know that, but surely it's simple to show the total length for a playlist in the same way as it shows for an Automix playlist?
Just seems silly to have to keep moving everything in to an Automix playlist
Then it's a wish, post it in the appropriate place.
Development of VDJ 7 has stopped. If the feature does get implemented, it'll be in VDJ 8.
