Forum: Greek Forum
Topic: virtual dj kai laptop
cfdj67LE userMember since 2013
kalimera paides.
antimetopizo to exis provlima: pao na paikso se ena bar me laptop-mikti stanton 2kanalo-karta hxou Numark djio kai virtual dj.kano tis syndeseis ton kalodion:1rca apo output1 sto line1-1rca apo output2 sto line2.o enisxitis einai sto master.(an einai kati lathos parakalo na mou peite sxetika).epeidi dokimasa polla diaforetika gia na exo proakroasi (me ta akoustika sto meikti?) kai den evgala akri koitakste ti ekana sto telos:apomonosa to deckA apo to koumpi ton akoustikon sto virtual gia na exo proakroasi (allios akougotan kai ta 2 deck taftoxrona) alla otan fortona to epomeno kommati sto deckA stamatouse na paizei to deckB!!!.(to mono pou de thimame einai ti leitourgiko exei to laptop giati den exo ksanapaei akoma alla ksero oti exei to virtual pro full eno ego dokimasa me to LE lite 7.0.2.parakalo kapoia voitheia oste na dokimaso kati allo prin ksanapao.efxaristo
geposted Tue 21 Jan 14 @ 2:55 am
Έχεις λάθος ρυθμίσεις στις επιλογές του ήχου σου.
Έπρεπε να επιλέξεις "External Mixer" αλλά εσύ προφανώς είχες επιλέξει "Headphones"
Η LE που έχεις δεν νομίζω να σε αφήνει να επιλέξεις External Mixer.
To PRO Full σε αφήνει.
geposted Tue 21 Jan 14 @ 5:36 am
ontos h LE den exei tetoia epilogh.ok efxaristo tha to koitakso
geposted Tue 21 Jan 14 @ 1:03 pm
kalispera kai pali.
file phantom ekana afto pou mou eipes kai katafera na paikso gia kana 15lepto.meta ksafnika to kanali 2 den epexe pleon???
einai kapoia rithmisi tou Virtual pou den kano sosta 'h mipos to programma den einai kanoniki ekdosi (ksexasa na to koitakso afto)?
ean valo tin LE ekdosi pou exo ego de tha mporeso na paikso?
na rotiso kai kati allo:
mporo na paizo sto 1 kanali me to virtual kai sto allo me to winamp kai ti prepei na kano gia afto?(apo syndeseis kai rithmiseis).
efxaristo gia thn mexri tora voitheia kai ean matho thn ekdosi tou Virtual pou exei sto magazi tha enimeroso.
thanks..
geposted Mon 27 Jan 14 @ 10:09 am
Η κονσόλα που έχεις (Numark DJ2GO) δεν έχει ενσωματωμένη κάρτα ήχου. Αυτό σημαίνει οτι η έκδοση LE που έχεις με τον ένα ή τον άλλο τρόπο θα σου επιτρέψει να έχεις προακουστική αρκεί να έχεις μια ή δύο κάρτες που να είναι ικανές να σου παρέχουν αυτή τη λειτουργία.
Απο εκεί και πέρα πες μας τι hardware διαθέτεις (κάρτα - κάρτες ήχου) ώστε να σου πούμε τι ρυθμίσεις πρέπει να κάνεις
geposted Mon 27 Jan 14 @ 11:47 am
ΟΠΟΙΟΣ ΞΕΡΕΙ ΑΣ ΜΕ ΒΟΗΘΗΣΕΙ PLEASE!!!!!!!!!!!!!
Έχω laptop (windows 7 ,64-bit ,4 GB RAM)
Eχω ένα dj midi controller (AUDIOPHONY DJAZZ PRO ΜΕ ΕΝΣΩΜΑΤΩΜΕΝΗ ΚΑΡΤΑ ΗΧΟΥ) που παιζει με virtual 7 LE και έχει διαθέσιμα mappers για την λειτουργία με VIRTUAL DJ PRO και TRAKTOR PRO, TRAKTOR PRO 2.
Το laptop "βλέπει" τον controller σαν κάρτα ήχου αλλά δεν του δίνουν εντολές για να παίξει.
Εχω κανει σωστα το sound setup [Inputs -> NONE, outputs -> HEADPHONES, Sound Card ->ASIO]
Και σωστη εγκατασταση DRIVERS.
Βάζω άλλο σκληρό (ενός φίλου) στο laptop μου για δοκιμή με τα ίδια χαραχτηριστικα και παίζει κανονικά ο controller
ΕΡΩΤΗΣΗ----ΥΠΑΡΧΕΙ ΠΕΡΙΠΤΩΣΗ ΝΑ ΦΤΑΙΕΙ ΤΟ Registry ΤΩΝ WINDOWS ΤΟΥ ΔΙΚΟΥ ΜΟΥ ΔΙΣΚΟΥ? Η ΚΑΤΙ ΑΛΛΟ?
ΕΥΧΑΡΙΣΤΩ ΠΟΛΥ ΕΚ ΤΩΝ ΠΡΟΤΕΡΩΝ!
geposted Tue 28 Jan 14 @ 3:48 pm
Κάπου δεν μας τα λες καλά...
Εάν η κονσόλα που έχεις παίζει με VirtualDJ 7 LE τότε δεν έχει Audio Setup
Εάν δεν παίζεις με LE αλλά με σπασμένη έκδοση PRO (που έχει Audio Setup) τότε προφανώς δεν μπορούμε να βοηθήσουμε.
Τέλος ο σκληρός δίσκος δεν έχει καμία σχέση με τον Controller...
geposted Tue 28 Jan 14 @ 5:32 pm
Ρυθμίσεις του VIRTUAL DJ LE
Όπως ακριβώς το δίνει το manual του djshop έχω κάνει το sound setup για το VIRTUAL DJ LE που μου έδωσε σε cd μαζί με τον controller
Είμαι νέος χρήστης στο site και γιαυτό έκανα επανάληψη του θέματος!
http://www.djshop.gr/pd/audiophony-djazz-pro-13255.htm?lang=el&path=-837799191
geposted Wed 29 Jan 14 @ 8:23 am
Apo oti thymamai, i konsola mporei na doulepsei se dyo modes (MIDI kai HId). Isws einai kai ta dyo ypostirizomena me tin LE (me tin Pro einai), alla kalou kakou des an gyriseis apo to ena Mode sto allo allazei kati.
geposted Wed 29 Jan 14 @ 2:16 pm
